Hi,
I know it has been asked a thousand times but would just like to ask if there are a few specifics to putting CM7 on a Desire HD
I have just put CM7 on std Desire and it is very good, but this benefits from Gingerbread, extra speed, and most of all memory access, so without doubt well worth it.
The HD however I think is actually pretty fast anyway, rarely notice any lag, memory has been fine so far, not a hint of running low. Gingerbread offers some improvement and generally a cool android experience.
I do love to customize & fiddle and really want to ROOT & ROM but not exactly sure why. (I also like some stability, fine when I have time to fix but sometimes I just need things to work.)
One big Question is with CM7 or any custom ROM has the ability for a program like Tasker to close down another app. Specifally I have a Car dock app that on BT connection with my car loads navigation & a seperate speed camera app. On BT disconnect it can close the docking but unable to close the 3rd party app. I think Froyo brought in this blocking i believe for security.
May seem a small thing but is annoying.
Also just to clarify, (perhaps I ought to understand if I am thinking of rooting)
What exactly is being downgraded to allow root? And does the custom ROM replace/upgrade this.
i.e. does this old firmware remain and the custom Rom work over the top or replace.
The upgrade to 2.50 firmware DID help my WiFi. How is this Firmware different from the whole ROM thing?
If I did return to original HTC ROM for warranty etc. I am guessing it would then get OTA upgrade back to the 2.50 stuff.
I am not sure if mine is Vodafone carrier locked, came from a online company but I thought affilated to vodafone but no splash screens or mention on About/Software so not sure what RRU i would need.
Will I still need the goldcard stuff to downgrade?
I will read info again but just came to mind.
Thanks I/A
bignose2.
Thanks I/A
bignose2.
