Desire Pay and go text and web
Intruder
Hmm strange one....
Done some searching here and google and not found anything to work.. Problem is rooted my phone and currently have LeeDrOiD Mod V1.4b on it. Try as I might I have not been able to set the APN, tryed loads !! none have worked :( Anyone on same tariff as me with a desire like to tell me your APN settings...?
Int
Sorry Its pay as you go text and web on O2
I am on O2 text and web. My settings:
Name : O2 MOBILE WEB
APN : payandgo.o2.co.uk
Proxy: <not set>
Port: <not set>
Username: payandgo
Password: ******** (starred out, sorry!)
Server: <not set>
MMSC: <not set>
MMS proxy: <not set>
MMS port: <not set>
MMS protocol: WAP 2.0
MCC: 234
MNC: 10
Authentification type: <not set>
APN type: default
Name: O2 MMS Prepay
Proxy: <not set>
Port: <not set>
Username: payandgo
Server: <not set>
MMSC: http://mmsc.mms.o2.co.uk:8002
MMS proxy: 193.113.200.195
MMS port: 8080
MCC: 234
MNC: 10
APN type: mms
(O2 Mobile Web is selected)
Hope this helps
Proxy: <not set>
Port: <not set>
Username: payandgo
Server: <not set>
MMSC: <not set>
MMS port: <not set>
MCC: 234
MNC: 10
APN type: default
Name: O2 MMS Prepay
Proxy: <not set>
Port: <not set>
Username: payandgo
Server: <not set>
MMS port: 8080
MCC: 234
MNC: 10
APN type: mms
Hope this helps
Thank you Password: ******** (starred out, sorry!) is password tring now will report back mate :)
After typing all them in my phone noow says cannot connect due to incorrect APN settings, i was on WiFi when I copied them down and thought i'd go on mobile data to test it. I am going to sleep on it, because I didn't change any settings. I hope it is o2 :S
My wife's phone (also on 02 pay and go) is saying APN error too, so it must be o2....
BTW she doesn't have a Desire
Tried that too mate dont have get settings for desire and pay as you go as amazing as that seems, as I was :O
That is strange, did you try the other way or maybe reset the phone so o2 thinks the sim is in a new phone.
There was a way in the menu system of some phones on o2 to request the settings.
Yup even tried the icon in apps... just errors and says call em
Proxy: <not set>
Port: <not set>
Username: payandgo
Server: <not set>
MMSC: <not set>
MMS port: <not set>
MCC: 234
MNC: 10
APN type: default
Name: O2 MMS Prepay
Proxy: <not set>
Port: <not set>
Username: payandgo
Server: <not set>
MMS port: 8080
MCC: 234
MNC: 10
APN type: mms
Hope this helps
Phew, woke up this morning and my mobile data works again! It must have been o2, try the above settings again Intruder
hehe, cool. I was on Thorpe Edge to be exact.
Hope your mobile data comes on again, it's a shame o2 don't have a service status page. If you go to settings, about phone, network it says a bit.
I'm starting to think its something to do with the rom, never had this problem before since I got the phone.. Might try another rom
