Desire S, need a fast answer
Desert89
Hi guys I will buy a memory card in less then 24 hours and now I saw something that I'm not sure of. I will buy it for gaming and other media.
Ofc the 32GB card. Here comes my question.
It says that the mobile supports up to "microSD, up to 32GB"
And on the internet i found a 32GB Memory MicroSD Card SDHC that I wish to buy. but here is the BUT! It's a SDHC card and it says only SD so can the mobile read from the card and use it?
Found this on the net:
MicroSDHC cards are a faster, higher capacity version of the microSD memory card standard. Any microSDHC compatible device can read both microSDHC and older microSD cards, but a microSD compatible device cannot read microSDHC cards.
So those that mean that the HTC Desire S cant read the SDHC or can ti read both types of cards? I need the answer fast and I need it to be 100% correct, please help me out - thanks...
All 32GB cards are SDHC, HC stands for High Capacity. SD Cards have been SDHC since 4GB and above. Also any device that can read SDHC can also read SD cards so your definitely good to go.
