Help Desire SD card issue
pav4n
Hi, I seem to be having an odd problem with my Desire, I'm running a Stock Desire on T-Mobile UK, using the SD card that came with the phone, I had no problems until yesterday when the phone reported that no SD card was in it, it is acting as if no card is in it at all when using the Samsung card that came with it. First thing I tried was to put the Micro SD card in my Laptop, it worked, could read the files, so I was worried that the card reader on the phone had gone, they I found an old Nokia 512 MB card and tried that in the desire, it worked fine, no problems, so I'm not quiet sure what to do from here.
I was thinking backup the micro SD that came with the phone, format it in windows, and then see if it works, one question, what would be the best way to back it up?, are there hidden files that require extra software rather than just dragging and dropping in windows?
If not then I will buy a new SD and hope that works.
Thanks for any help :)
Don't think it is needed, but for the safe side: activate the option "Show hidden files and folders" in Windows.
Then go to your SD card, select all (ctrl+A) and copy everything to your pc.
Format your SD card and put your data back.
