Have to say it was fine on ICS 4.0.3 but the update to 4.0.4 has caused a couple of issues. Some of the widgets don't work on 4.0.4 and I had to search for alternatives. Battery drain also seemed to increase, but I have since wiped and reinsatlled all my apps afresh. So far so good.
The phone itself is fine, works well and it's a welcome change to have loads of memory for apps without having to root, repartition, use apps to SD patches. GPS is quick, the screen is very good, and everything just seems to work well. Have not rooted or flashed a custom rom to mine yet. The camera does suffer from a pink spot in the centre, but on real world pictures it isn't noticeable (only if your taking a picture of a white wall LOL) No issues with WIFI, connects to our home network every time, first time. Use it in the car for satnav. I like the size of the S2, big enough screen for me to see easily without being too big to carry about.
Sure the S3 is better, but I didn't want to pay out a lot - set myself a budget of
