Root Desperate for Help!
Alright well, I successfully ran Android's Honeycomb [3.0] on my Nook Color [1.3]. I did so with the use of my mac, now I know how to push the Android market onto the device; my only problem is that this ****ing thing won't connect to my mac. It's driving me absolutely insane, I've looked everywhere and can't seem to find a solution. I've played around with the USB Debugging option under Settings>Applications>Development and nothing happened. I've switched USB cables and still no sign of life. Someone...please help?
Did you look for a "connect to usb" option on the status bar on your NC?
HC is Flaky. Why would you want that?
Are you try to do ADB via your Mac? You need drivers on your Mac to do that.
