anathematized1
CAN I PLEASE AT LEAST GET ACKNOWLEDGEMENT THAT SOMEBODY SAW THIS?
For three days now I have been scouring the Internet for help and I can't even get a single response and morons get instant responses to stupid questions. I'm going to just copy paste now...
So I used the ACS/Shabbypenguin root method (do a Google search, I can't post links...) and followed the directions exactly. Well almost exactly, I knew of some issues so this is what I did...
First I downloaded Superuser & Superuser Elite (I previously paid for it on a different phone).
Then I downloaded the drivers and Odin and both kernals.
I installed the drivers and put my phone into development mode.
Next, I turned off my phone then turned it back on in download mode and flashed the pre-rooted kernal as per the instructions there.
Finally, I went through the process again to flash in the stock kernal.
Now the other users had issues with USB connection and the phone not being recognised, the answer to that was on page 11 of the above linked thread (editing the vold.fstab file). I did this (using ES Root Explorer) as per the instructions and restarted.
Things seemed fine for half a day. Now my phone randomly restarts, but not always randomly. I can perform specific actions to cause it to freeze and reboot (example, simply opening the vold.fstab file does this EVERY TIME, but I was able to copy/paste it to the SD card and then open and edit it and even copy/paste it back, all using ES root explorer, and no crash/reboot unless I open it specifically and yes, that's with having the system mounted as R/W).
Another thing I noticed since rooting, and it still has maintained the rooted status, is that any time my phone restarts or I restart it, I open the system tray and this stupid "tip" toast message comes up that, prior to rooting, only came up once. Now, it comes up only once after a restart but resets every time.
I tried to sign up for the ACS forums but for some reason, I've not gotten a single registration e-mail from them and messaged half their admin with no response (the fact that the site has no cancel account and no re-send activation option troubles me enough as it is and in my opinion, should be internationally illegal).
Anyway, that's the issue, I need to resolve these random restarts, which may or may not be caused by this vold.fstab file.
Also, I connect now (before when I did the fix, it worked), the computer doesn't recognise the phone so I can't even re-flash using Odin, but the phone works (until randomly restarting which is a pain...), so I am at a loss as to what the actual cause was and since nothing I change sticks when it restarts, I have no idea what the deal is.
EDIT / DELETE
REPLY![]()
anathematized_oneToday, 12:49 PM![]()
(Last edited by anathematized_one; Today at 02:16 PM.) Reason: update
#2
Junior Member - OP Thanks Meter 0
More Info >
Some more information...
Nothing I change sticks. I have programs that I uninstalled, but they still show up in the system tray after a reboot (if I click it, it says that the program is not installed, but it still shows up).
I tried swapping back the original build.prop - didn't stick.
I tried factory data reset - didn't do anything.
I tried a restore in BusyboxPro (stericon or something is the dev) - restored but there were some "errors".
Tried temporarily unrooting (Superuser Elite) - nothing.
I read about a power button issue - my power button is fine.
There is something wrong specifically with the OS in some way that certain actions cause it to freeze and restart. I have a game, "Deathworm" that I can play with no issues or freezes. I can do a few things but:
if I get on the mobile browser, sometimes it will freeze and reboot.
if I run AppManagerPro III, sometimes it crashes when calculating the cache size (always when it gets to 70/125 or whatever the total is, but always at 70 if it DOES crash).
Now I went into task manager and went through and cleared all the app data individually app per app. Before when I tried to do this (before restoring in Busybox, before restoring the original build.prop, etc), it would crash when I went into the downloaded tab of the thing to clear the cache. This time it didn't crash on me.
Other root stuff I have installed which was working before the random rebooting issue:
- Script manager (free) and V6 supercharger (also unsupercharging wouldn't stick, which I tried before restoring the build.prop manually)
- SuperUserElite
- App Manager Pro III
- SD Maid Pro
- ES File Explorer (free version I think)
- BusyBox Pro
- SU Update Fixer
- Screenshot It
After everything I just did, it seems to (for the moment) be working again, I am just waiting to see if it crashes again. So far I have opened and closed App Manager Pro III a few times and it calculated cache sizes with no crash. Right now, SD Maid Pro hasn't crashed yet open, hide certain tabs (clearing the data so I had to reset those options), close, reopen, scanned with system clean and app clean and actually did the app clean, so far no crashes (my phone would normally have crashed by now), cleared databases and no crash.
Also while I was in there, two programs I uninstalled via the system tray (menu button, edit, uninstall) that kept coming back were a buld.prop editor and some wonkey game (Fall down) or something, anyway those were in the downloaded section of task manager and I uninstalled them through there. Maybe that did it?
And no... still freeze, reboot and not saving any changes.
EDIT / DELETE
REPLY![]()
anathematized_oneToday, 02:21 PM![]()
(Last edited by anathematized_one; Today at 05:18 PM.)
#3
More Info >
So far I've also tried uninstalling practically everything I installed and those changes aren't persisting (the uninstalled apps remain uninstalled, but reappear in the system tray or on the home screen if I had an icon there for it).
No changes I make to anything persist except things I save or copy to the SD card.
Tried factory reset again, still didn't stick.
EDIT / DELETE
REPLY![]()
anathematized_oneToday, 05:28 PM![]()
#4
More Info >
So apparently SOME others have this issue without rooting, I can't tell, there's not a ton of reviews that I can find beyond "STRAIGHT TALK CUSTOMER SERVICE THIS PHONE IS CRAP".
I hate to keep bumping this, but every time I have an issue, I am highly detailed in things and I NEVER EVER have EVER gotten a response EVER on this site, EVERRRRRRRRRRRRRR.
I really really really don't want to waste another ~$200 for nothing.
I would appreciate even a response of "yeah I have this problem too".
I don't want this to die like all the other threads I started...
