Help Determine if Battery is Faulty
eoinymc
Hi,
I know there are plenty of threads about batteries, but I was wondering if anyone can tell me if there is any way that I can tell if my battery if faulty?
My wife and I both bought a HOX+ a couple of weeks ago and it seems that her battery last a lot longer than mine.
I have a lot more apps downloaded, but they aren't running when I check the running apps in the app manager. So I'm at a loss to figure out why mine isn't as good as my wifes.
Any ideas in how to check if it is faulty?
Cheers,
Eoin
The app manager isn't your friend on this.
I would suggest GSAM Battery Monitor.
The graphs tell more and are maybe easier to read in landscape. See if both phones are really getting the same signal during battery use.
On the lower left, tap that to see what's hoovering your battery. When the screen comes up, tap the top, choose to view time held awake. Her phone may be sleeping properly, yours may have an app preventing it.
Post back what you find, play around with various views on both phones.
Could be the battery but it's likely something else.
Thanks...It says that maps is top of my list on apps holding it awake..but I don't open maps, so I can only assume it's another app using maps?
Any way that I can see what it is actually doing?!
Cheers,
Eoin
