Root [DEV] CWM Work In Progress
rbheromax is working on compiling CWM right now. I believe there will be a stock ROM (recovery) as well as an OC ROM coming out first. I've been sending him the partition exports and technical details from the phone.
I believe we had a breakthrough yesterday in regards to finding the boot partition, so we are making progress.
Glad to see another group working on the Illusion. I have a few interesting files for ya ;)
https://github.com/Motorhead1991/android_kernel_samsung_s5pv210
100% source built and functional, if you set it up right. (This is set for a remote initramfs). I have another project in testing on the Galaxy Proclaim (identical device), so depending on how this works out here, I may push my release date up.
the proclaim kernel works like a charm that DroidHost put out, from your source, and i hear a rumor that cwm is in testing and debugging for proclaim and illusion that would be sweet...
CWM in testing for the Samsung Illusion at androidarea51.com... thanks to Motorhead should be ready for release in a couple days....
I don't think that was supposed to be visible... Oops :D
Thank you for pointing out our oversight, but unfortunately it needs to go back under restricted access. Now y'all know it exists now....
Ya the ADMINS forgot to restrict the access to those VIP boards to the VIPS and admins, beta testers, and Global Mods, OOOPSSSSSSSSSSSS! :D
Hehe, the public will get an updated version of that also. It's not even out yet and I'm updating it. :p
should be wicked...
