Spz0
Android Expert
I am noticing issues when attempting to format /system from the updater-script.
Using Sues CWM 5.0.2.7 on Vitality (although dev/blocks are the same), which only requires 2 args, so these _should_ work, but do not format or mount.
The Code is solid -- no errors. Its just not formatting or mounting the stated partitions.
As Im not too familiar with Samsung development, any help from devs would be greatly appreciated.
Thanks in advance.
~Spz0
Code:
format("MTD", "system")
mount("MTD", "system", "/system");
package_extract_dir("system", "/system");
Code:
format("MTD", "/dev/block/stl12")
mount("MTD", "/dev/block/stl12", "/system");
Thanks in advance.
~Spz0
