Root Dev Tools
jreink01
Android Expert
I have a question, I have a triumph rooted and flashed with cm7. I was messing around got into dev tools, bad behavior, and I accidentally hit wedge system (5 minutes). I tried backing out, even tried powering the phone off but nothing would work. Then all of a sudden it rebooted. It appears nothing changed. Can anyone explain what. that button does? Thanks
the bad behavior section of dev tools is to cause "bad things" to happen inside the Android OS for debugging purposes.
you quite literally "wedged" the system, for 5 minutes or so, and then it rebooted.
everything you did was clearly labeled. what did you think would happen?
So, I take it eveything is ok then? That was just for the five minutes then
Have you had any issues since then? It shouldn't have messed anything up.
It's probably best not to mess with stuff if you don't know what it does (unless you make a backup first).
It appears to be working ok, although I havent used everything the phone has. And, I did not press that button intentally, I was exploring new things and when I got into that menu, I accidentally hit that button by mistake. Serves me right, huh?? LOL
