Root [DEV][WIP][PORT][4.1] Android 4.1 Jelly Bean JRN84D [6.30.12]
CooLoser
My Original XDA Post: [DEV][WIP][PORT][4.1] Android 4.1 Jelly Bean JRN84D [6.30.12] - xda-developers
Hey guys,
Im going to attempt to port Android 4.1 Jelly Bean from DaXmax's base and will try to show you the progress I make + photo's etc just to keep you updated.
How am I doing this?
-Use the latest Rom base for Jelly Bean from DaXmax
-Latest CM9 nightly build for libraries, vendors etc..
-Modified CM9 kernel
-Use my brains alot
I will post in this thread daily with answers and that kind of shizzle.
What Works:
-Integrated Root
-It boots
-Touchscreen
-Bluetooth
-GPU
-Camera
-Soft keys
-NFC
-Project Butter
-SDcard
-ADB
-USB Debugging
What Doesn't Work:
-Audio
-Wifi
-3G/Any Connection
-Other stuff I dont yet know about.
-Some app FC's
Screenshots:
Status:
Smooth as butter and is booting. Dont mind the Random offsets
Im currently working on the Wifi Fix meaning Google Now!
Download:
Dev-Host - JB_NS4G_beta.zip - The Ultimate Free File Hosting / File Sharing Service
Devs who wanna help, please help us solve this...
The Wifi Problem..
E/WifiStateMachine( 1583): Failed to start supplicant!
E/WifiHW ( 1452): Failed to open wlan fw path param (No such file or directory)
E/SoftapController( 1452): Softap fwReload - failed: -1
E/WifiStateMachine( 1583): Failed to reload STA firmware java.lang.IllegalStateException: command '9 softap fwreload wlan0 STA' failed with '400 9 Softap operation failed (No such file or directory)' W/CommandListener( 1452): Failed to retrieve HW addr for wlan0 (No such device)
D/CommandListener( 1452): Setting iface cfg
E/WifiStateMachine( 1583): Unable to change interface settings: java.lang.IllegalStateException: command '11 interface setcfg wlan0 0.0.0.0 0 down' failed with '400 11 Failed to set address (No such device)'
