does anyone know a developer named dydghks or he may go by hzx197920
well anyway I found this
Google Translate
and other d1lu roms here
http://main.develoid.com:82/lg/Optimus LTE2/Rom/
I wanted to see if I could mod cm-10.1-20130207-UNOFFICIAL-d1lu-Alpha.zip to work on the Motion
well it boots, but most of the stuff does not work, and to be honest I do not think it works 100 percent (alpha) on the phone it was intended for
BUT IT IS A START
I would like to find dydghks or hzx197920 and see if he has a device tree for this so that we may use it somehow
I think only developers should install my ported version of this ROM, and I want you to backup your modemst partitions before you do so with this
lgm_modemst_bakup_v2.zip
This ROM boots
no sound, no nothing, etc etc
if the screen powers off you have to reboot (battery pull) it will not wake back up with power button
NOTHING WORKS - it boots, but maybe we can learn from it
it is the first JB 4.2 rom for the Motion
it has some stuff i had not seen before (CLUSTER OS)
I hope that I have made this thread too complicated for the average Motion User, because you should really not install this rom unless you are trying to learn from it
I do not want to hear any complaints about this thing not working
I am not gonna make this thing work
it is for learning only
got it, get it, good
ok, i will shut up now
I would like to thank interloper for letting me use his files host
http://hroark13.waywardpilgrim.net/lgmotion_cm10.1_pre-pre-pre_alpha.zip
hK
Google Translate
BUT IT IS A START
This ROM boots
hK
