In the Android N Developer Preview, we have a feature that will let you adjust the DPI of the display simply by using a slider. The thing is, this slider has a certain limit for the max and minimum but there's a way to change this.
All you have to do is enable Developer Mode, go into the Developer Options page of the Settings and then look for a 'Smallest Width' option. Then just change this number to something bigger than it currently is (as the bigger the number, the smaller your UI elements will be).
