Enter GroupMe room
https://web.groupme.com/groups/3471053
"This group does not exist or you do not have permission to view it"
I really prefer irc
Enter GroupMe room
I really prefer irc
Hopefully something is figured out. Sounds like a few ideas are mentioned as porting a driver from the 3.0 kernel, some kind of "thingy" someone mentioned that is failing, and a eri.xml edit or some sort. Come on everyone, giving up never got us this far. It took several months just to get cwm on this phone, a whole rom should have taken longer anyways. We all expected this. :] I'm not gonna gove up. I'm searching Google all over for why CM9 has failed on other devices and trying to learn about how read problems in logcats, and applying that knowledge to see if it's the same problem other failed CM9 builds have had.
Got outbid on the first, and there is a good chance I will be out bid by the same person on the second
Or.........how about looking at CM9's that WORK. I visited CM's website and clicked on "devices". When you scroll down to the LG Optimus phones there are a number of them that already have CM9. Then I looked for a phone similar to the OE and found the Optimus Sol. It has the same GPU and a slightly different Snapdragon chip but overall not too different. Since Android is open source, there would be nothing wrong with downloading, tearing open and studying that zip file......right?? Seems like you would find a wealth of knowledge, tips, methods in there. If you look on XDA, there is a developer, andr00ib, that has a CM9 ROM for that phone that could also be downloaded and extracted to see what works.......right?? Just a little quarterbacking from the couch.......and my .02 worth!!! :smokingsomb:
Or.........how about looking at CM9's that WORK. I visited CM's website and clicked on "devices". When you scroll down to the LG Optimus phones there are a number of them that already have CM9. Then I looked for a phone similar to the OE and found the Optimus Sol. It has the same CPU and a slightly different Snapdragon chip but overall not too different. Since Android is open source, there would be nothing wrong with downloading, tearing open and studying that zip file......right?? Seems like you would find a wealth of knowledge, tips, methods in there. If you look on XDA, there is a developer, andr00ib, that has a CM9 ROM for that phone that could also be downloaded and extracted to see what works.......right?? Just a little quarterbacking from the couch.......and my .02 worth!!! :smokingsomb:
This sound like a great idea and it might work (not that i would know i'm far from a developer lol!).
I have the LG optimas S (Sprint) running 4.0.4 laying around in my house. Could trying transferring the ROM to the LG Elite for giggles. lol
I've heard that the Optimus S is the closest to the Optimus Elite. I would try porting CM from the S to the Elite, if anything. That, I would think, would be the easiest way to go about it.
Haven't turn that bad boy on for 4-5 months. Just turned it on still works and found me a SD card for it in my house.![]()
No no no. The optimus S is nothing like the elite. You flash that Rom, there is a chance brick.
The Optimus S is just the Sprint version of the OV. That's Froyo based. There are Gingerbread Optimus' that would be more similar.......like the one I mentioned earlier...the Sol.
Its okay, there is a donation thread for a cell now. So the Sol is the closest to the elite? Might be worth looking into as well
