Well, that's good, the screen is still working. If the phone won't turn on at all then it's time to take aggressive action. First, try booting into recovery mode one more time.
Ensure the R and SPACE keys are pressed down firmly, and no other keys are pressed. Then press the power button to turn it on, while holding those keys. If it still doesn't do anything different, then here's something a little more brutal you can do.
You can flash the Devour's SBF file onto the phone using RSDLite, which is about the same concept as formatting your computer's hard drives and reinstalling a fresh operating system. Use the SBF file CALAND_X_01.15.08P_MONSTER_01.sbf and use the guide provided Using RSD Lite to flash an SBF file -- correctly - Droid Forum - Verizon Droid & the Motorola Droid Forum. That guide is for the Droid, however, but to get your Devour into bootloader mode you take out the battery, hold keys "E" and "R", then plug the USB cable into your phone and computer. (Step 4)
Please note that if you flash the SBF file you will have to redo all steps to root your phone again if root access is desired.
If something goes wrong and your phone is permanently bricked, go to a Verizon store and see if they'll just send you a new one. They did for me, even though my phone was rooted and wouldn't start up. Just say you tried to install the over-the-air update and it failed and showed you the blue bootloader screen.
If you have questions, post back here, I had to use RSDLite and the Devour SBF twice recently.
Hey p025, you know how to change the build.file from 7 to 4? Like they said on the other thread?
blazen, you mean to get the Droid X bootstrap to work on the devour?
if you havent figured it out yet, just go back into whatever app you used to change it, make your system rewritable and click on the file then change it back from 4 to 7
I would but superuser isnt granting permissions anymore.
hm, well either you can unroot your phone or flash it back to its original using the SBF, and then manually rooting it
we dont have a need for the droid x recovery as of yet, so id keep it on your sd card/computer if and when we get a custom rom/update
flashing the sbf-use RSDlite, doesnt matter which version of it though
and yeah, that file is the one to use
Just wanted to give everyone the update...it worked!!!
