OneTrickPony
Hello gais!
So ive had my DHD working perfectly for 2months, but all of that have changed the past weeks.
At first it was just the annoying(and common) headset icon turning up randomly and routes all ur sound to the minijack output. Luckily i found a workaround for it, its still annoying, but i love this phone to much to let it bother me.
However the past days a new and unbearable problem have surfaced.
The screen(which imo makes or breaks a phone) have lost the crispy vibrant look it once had.
Now on the grey menu bar the the bottom I have green tinted lines going across it. These lines also appear on every grey menu bar. I also had a day where the screen would swap between a red and green tint while is was typing.
The wallpapers looks like someone put a cheap glare effect on them. So the lighter parts of the image got a poor glare effect.
But when I run an app like for example Angry Birds the display is totally fine. The problem seems to only affect the menu.
A screenshot of the background when viewing the Gallery. (Yes, it does look that bad)
This is a example image which ive edited to resembles what the default wallpaper looks like on my phone:
Ive done a factory reset with little hope of improvement, just wanted to see if more people had this problem and if there is any ways to deal with it or if its a permanent hardware fault.
So if anyone can shed some light on this problem I would be very thankful!
Thanks!
Thanks!
