Root DHD downgrade please help!
rwtelecom
ace pvt ship s-off
Android 2.3.5
Software number 3.13.720.2
kernel 2.6.35-g931a37e
Baseband version 12.65.60.29U_26.14.04.28_M
radio 26.14.04.28_M
Guys these what i got on my device which i want to downgrade... i have been trying a lot of tricks and procedure in this forum but still i cant root my device.
i want to install arabic rom thats why i need to downgrade to 2.3.3
please guys i need your help!
thanks in advance...
You're S-OFF are you sure you're not already rooted? If no, Gingerbreak might be able to root for you.
From hboot (the screen where it tells you you're S-OFF), if you select recovery, what is it? Clockwork?
You can also do a check to see if you have root access by downloading the 'Terminal Emulator' app and typing 'su' (without the '') and if it comes up with a # then you have root :)
Yes, when im in recovery i got (CWM). i did check "su" and i only got "$" not "#". is it possible to downgrade my build (3.13.720.2)?
yes sir i have su on my device, but why i always got 131 error every time i try to downgrade to 2.3.3? is there any way or is it possible to downgrade my build 3.13.720.2?
You don't need to downgrade to 2.3.3 if you have clockwork installed. What's the ROM you want to run, all you need to do is put the zip file for the ROM on your SD Card and isntall via clockwork.
There's a bit more to it than that, but if you let me know the ROM, I can give you instructions.
Hi Sir thank you for your kindness here is the rom that i want to install RUU_Ace_Gingerbread_S_HTC_ARA_2.42.415.1_Radio_12.54.60.25_26.09.04.11_M2_release_193079_signed.exe
im on 2.3.5 build 3.13.720.2
everytime i will try to install this rom i got 131 error
i want arabic rom that is why im pursuing to install this rom...
The ROM you have linked is an RUU (as can be seen by the .exe extension) and can't be flashed with recovery. Your best bet (and probably the easiest way) is to flash a custom ROM with Arabic support. This ROM definitely has Arabic - [ROM][Feb 17]RunnyDrOiD v5.0 By PVTEAM |Ultrafast & Smooth|2.3.5| Sense 3.5|Tweaks - xda-developers
If you need any help getting this onto your phone let us know :)
i guess this is just an arabic support, yet its not a full arabic rom... anyway downloading & i will update soon... Thank you Sir!
