bartek4311
I am wondering if i bought a 1600mAh battery for my DHD off Ebay for
Thanks, by a dedicated 2g/3g switcher do you mean one of those apps off the market? Sorry if this sounds a bit stupidI Totally agree. External batteries are the way to go and i would also suggest you get a dedicated 3g/2g switcher so the phone isnt constantly looking for a 3c signal-this eats battery
Thanks, by a dedicated 2g/3g switcher do you mean one of those apps off the market? Sorry if this sounds a bit stupid![]()
You don't need an app for it mate, if you hold a blank area of any of the home screens, you'll get a menu up. From there go -
Widgets -> Settings -> Mobile Network.
That will add an icon to that homescreen that allows you to switch off 3G when you don't need it. You can do the same with Wifi too.
Yeah, with it on, it's constantly looking for a better signal than the one it currently has which is a killer when it comes to battery life.
Same with wifi too with all accounts, a lot of people switch wifi and mobile network off when they go to bed/it's not needed.
