volvo940seturbo
Member
I have just got my DHD, have two Desires and a Wildfire, and have been very happy with the build quality on them all so far. But on the DHD apart from the sim cover issue which seems to be well covered here, has anyone noticed the edges of the screen??? to me it seems the screen is to low in the case, on mine if yu run your finger across the screen towards the side of the phone, the case seems higher than the screen, and is quit a rough edge to it.
This is all round the edge of the phone. The screen seems to be aligned in the casing, it just seems as if it sits low and not flush with the side of the case.
Are they all like this? Or is this another build issue with the DHD.
Other than this, I am more than happy with the phone, and can put up with it, if there are more like it, but as I only have a seven day exchange, I would rather get one that is correct, if even this is a fault.
Cheers
Cheers
