Help Dial Pad Question
Dwnshft
I was just wondering if there is a way or an app that allows the phone dialer do be customized to change its appearance?
I'm rooted with 2.1 Telus Light and Fast ROM, Launcher Pro Plus home and over-clocked if it helps.
Any advice would be appreciated. Thanks
Pull Contacts.apk from /system/app and rename to Contacts.zip. You'll have to edit the *.png's without unzipping it. If you want to change the dialpad while in call you'll have to pull Phone.apk from /system/app .
