i think you have to have root. cuz what you would do is go into settings>applications>manage applications. find the built in dialer, tap it, and find default and press "clear defaullts. but its grayed out for me. so im assuming it takes root access
btw, the only way i found to use it all the time(easily) is create an icon for it on the dock bar in launcher pro
rooting isn't hard to all that dangerous anymore. There's a script that runs in a cmd shell that does it for you with the click of a button. If you want it, I can give you a link(I didn't make it, nor am I taking credit for it)
