Dialpad issues
Questkev
I have an Android phone, its having the classic dialpad issue, where if while in a call if I go to enter in say my voicemail password, I can press the button, but nothing will occur. Its an Huawei Ascend 2.2 (stock upgrade) I didn't post this there, because after hours of searching, I have found out that it affects numerous phones varying between makes and models.
I was just wondering if there is a fix for this, not a bandaid.....
Sometimes I will have this problem if I send the phone app to the background(hit home, back, whatever), then do something else, then try to pull it up again. For me, it is solved by pulling down the notification bar, and opening the phone app from there (clicking on the same line as the red call end button). But HTCs are totally different phones, not sure if that would help.
just by searching I have seen topics posted about the Hero, the Evo, the incredible, the Droid, the Ascend (this one), etc. To me thats different makes and modles of phones. None of them were recent topics.
I have never had it affect my phone, but i have my girls phone here in my store with this problem. I even did a factory reset, and still has the problem. After doing some research, it seems when you key in a number during a phone call it uses DTMF tones, and well, it seems there are no settings to change anything associated with this issue. upon further research, the reason why most people can do a FC on Dialer and Dialer Data, and get it to work, is because the Dialer actually figures out what button you press, and the plays the corresponding DTMF associated with that button, and doing the FC actually allows the phone to restart the app, and Voila it works. To me this is a bandaid. A fix that works, but not a true fix.
