Dictionary on Hero
pcb007
Hello, can anybody please tell me how i can access the dictionary on the hero, added a few words by mistake that are wrong. Other threads suggest settings, locale,text then select user dictionary, unfortunately the dictionary option is not there for me. Any ideas please? Thanks
Paul
OK, You cant edit it but, to clear the user dictionary on the HTC Hero, you will need to navigate to Settings, Applications, Manage Applications. Then once there, you will need to scroll down and find “Touch Input”. Click on that, and then tap the “Clear Data” button.
Again, this may not be the most ideal way to remove a word or two, but in the meantime it seems to be the best option. But moving forward, lets hope that HTC will offer a nicer way to edit (or delete) on a word by word basis.
