Help Did codes change for secret programming
starstress
Whenever I dial one of the numbers I used to dial, it atually calls the number and just says my call cannot be completed (yes I made sure I had service)
Any help?
FYI, Im tryna set my phone to evdo only so I really test this 3g out
Any help?
Why do it like that, easier way is to download LTE OnOff from the app store thats what most others do
I'm running bobz latest build and have been using *#*#4636#*#* all day trying evdo in different locations.
Yes just download LTE OnOff which is basically a shortcut to the secret menu and since you are using the rom you wont be able to access the menu by dialing the numbers.
