Help Did DL09 mess up bluetooth?
jbposell
After the DL09 update, my Fascinate no longer automatically connects to my car's handsfree setup when I get in the car. The only way I can get it to connect is to unpair and remove it from the phone, then set it up from scratch when I get in the car.
To make matters worse, I can only unpair the device (under Bluetooth Settings) infrequently and, it seems, randomly. 9 times out of 10, it just simply sits there in the listing of devices and does nothing.
Anyone else experienced this? Anyone have a solution?
BTW, this is pairing with the Audi MMI system (which has had no changes or firmware updates).
Thanks!
I don't think this update really changed much in the way of bluetooth, as my phone connected perfectly fine with my Genesis after the update. I sometimes had a problem where if I turned my BT off after getting out of the car, then turning it back on before i got into the car it wouldn't pair correctly. So I ended up just leaving BT on since I never really noticed much of a battery drain with it on. (Allowed me to be lazy as well.) Dunno if that's part of the problem you're having?
