Did I actually upgrade to ICS?
DemDog
I updated to ICS yesterday afternoon, or at least I thought I did. What makes me think things did not go too well is when I go into Settings > About Phone > Software Information. I find the following: Android Version 2.3.4 and Sense Version 3.5
I also went into Settings > Software Update > Status and saw this: Name: Rezound 3.14.065.12 71ORD then Status: Update Successful.
I don't really see any changes or loss of performance since I did the upgrade and based on what others have stated in other threads I should have something even very small go wrong with the upgrade.
Did try to see if I could get rid of some of the Verizon bloatware and that could not be done.
Any thoughts would be appreciated.
Sounds like you only got the first update (the prep one)... be patient and give it a couple days, the second part should come through and finish the upgrade soon.
Problem solved. Called VZW tech support and a nice young guy helped me get the update installed. Seems that the battery has to be almost fully charged for the update to install. I was at like 70% when I began the update yesterday.
So I plugged the phone into a wall charger and what do ya know, the update installed. Took like 15 minutes but it is working. Now to play with it some to see what all I got.
Thanks for your help.
