I was using tacoroot and the htc dev unlock, to unlock and was following the steps on [GUIDE] Comprehensive S-OFF/Root Methods - xda-developers
cd C:/Android
md5sums RUU_Vivo_W_Gingerbread_S_VERIZON_WWE_2.18.605.3_Ra dio_1.09.01.0622_NV_VZW1.92_release_199487_si.zip Result should be cea499f51b40055ffd118960e1e73255, if it isn't, redownload the miniadb zip.
md5sums 1.09.01.0312_vivow_Radio_PG32IMG.zip Result should be ea6b98be48210d7797e62362f49ff751
md5sums misc_version Result should be 050f55d34ddbcc860efa5982491437de
adb devicesResult should be your phone's serial number.
adb push CWM-SuperSU-v0.94.zip /sdcard This might take a minute or so. If it gives an error, try "adb push CWM-SuperSU-v0.94.zip /mnt/sdcard"
adb reboot bootloader This should reboot your phone to a white menu, once it is there, continue.
fastboot devices This should return your phone's serial number.
fastboot flash recovery recovery.img This might take a while, be patient and do not interrupt it. Once it is done, use the volume buttons on your phone to navigate through the menu until RECOVERY is highlighted, then press Power to select it. Your phone will reboot into another menu, once it shows up, select "install from sdcard" then "choose zip from sdcard," then scroll down and select CWM-SuperSU-v0.94.zip, and accept it. Once it is finished, press power then select reboot. Once you are fully booted, continue with the instructions.
adb push misc_version /data/local/tmp/misc_version
adb shell chmod 777 /data/local/tmp/misc_version
adb shell /data/local/tmp/misc_version -s 2.18.605.3
adb reboot bootloader This will reboot you to the white menu again.
fastboot devices Result should be your phone's serial number.
fastboot getvar mainver Result should be 2.18.605.3. If it isn't, make sure you didn't get any errors in the above code and everything was copied correctly.
i kept getting right here and it wasn't working so i used the flash mod it was telling me to use to flash RUU_Vivo_W_Gingerbread_S_VERIZON_WWE_2.18.605.3_Ra dio_1.09.01.0622_NV_VZW1.92_release_199487_si.zip
and that worked kinda, then i get fed up at that point and used the tacoroot method, i had everything in a c:\android folder
adb shell /data/local/tacoroot.sh --root
adb wait-for-device Running the step before this will reboot your phone again, this time it will be bootlooping, meaning it will not boot fully and get stuck on the boot animation. Once your prompt comes back after this step, you're good to continue even though the phone isn't fully booted.
adb shell /data/local/tacoroot.sh --undo This will reboot your phone one more time, this time fully stable and will boot completely. Continue once fully booted.
adb reboot bootloader This will reboot your phone to a white screen with a few options. Once you are at this screen, continue with the instructions.
fastboot devices Result should be your phone's serial number, again.
fastboot getvar mainver The result should be 2.18.605.3. If it is not, something was not done correctly, you'll need to restart from the beginning.
fastboot erase cache
fastboot oem rebootRUU
and got to this point
not its a sliver HTC and if i unplug my device I get a RUU on the white android background, It says its going to take awhile but its been stuck like for a few hours, is it bricked or what?
cd C:/Android
