Same for me.I've never experienced lag on mine and I am not rooted, phone works smooth
When in car dock mode, there are times when the clock on the notification bar stops working for a couple of minutes...seems like everything else continues to function properly.
Laggiest phone I've ever owned.
Example: when I tap a direct dial icon it takes a full 5 to 8 seconds to initiate the call. Simply inexcusable for a supposed $600 device...
JB caused the lag for me! Worked so much better on ICS...
Did you do a Factory Data Reset after upgrading to Jelly Bean?
... Thom
Why would "rooting" the phone make the lag go away?
Always been an HTC guy and even with Sense, I never noticed lag. Same thing with my coworkers Samsung and my wife's iPhone 5.
Took a chance with the Razr HD and the lag is noticeable...before and after the update and with a factory reset (this should be done after any update in my opinion).
Everything just seems "choppy" on Moto devices and scrolling is just not smooth like it is on other phones. I will definitely be rooting as soon as I have a few minutes to sit down and play with it.
I'm waiting for 100% functional custom roms. Right now the only custom roms. in which everything works are basically stock rooted roms.
