xmr405o
Android Expert
Sorry, I am too excited. I haven't loaded it up yet but just saw that Pershoot just released an Overclock kernel up to 1.4 ghz.
I'll be the guinea pig. haha
Kernels are available for both Froyo and GB. Yay!
Update: Added a pic. Quadrants went up to 2800+ average. The highest was 2951. Makes Vegan GB run smoother and apps load super fast. Youtube is still choppy. We really need hardware acceleration on the GB roms.
The kernel is preset to Ondemand. No noticeable battery temp issues. It does warm up a little if you decide to crank up the max and min settings to 1.4 ghz. I wouldn't recommend that. I'll keep the tab running on Vegan GB to test battery life. The OC kernel has reduce voltages so I'm hoping that battery life doesn't take too much of a hit.
More than likely, I'll go back to Vegan 5.1.1 with OC because I can't stand not having hardware acceleration. I have a feeling that with the OC kernel and my Vegan 5.1.1 setup, I will have better performance. I'll go back to Vegan GB when the video issues are resolved.
You just have to be smart about it. If and when other kernels are released with higher CPU speeds, it doesn't mean you should have to flash those kernels.
i guess your right.. can you tell me how to flash this kernel right?
. I also asked the same questions as you. Here's his answer.
