Help Different Backrounds for Xoom
Is there an app, or is there a way to have a different backround image on each screen for the motorolla xoom?
If you mean wallpaper then its quite simple as you don't need an app. Simply make sure that you get an image, any image, at a resolution of 1408x1280 pixels. Save any you fancy on your PC and hook up your Xoom via a USB connection. Then copy the image(s) to your Xooms SD partition - you can create a folder in the previous step if you so wish - and then go to your gallery and select the image you want/copied; once it is displayed full size tap the top right of your screen and select 'set picture as' > wallpaper > done. :D
