Difficult to enter characters
Biffos
It is very difficult to enter text in the Samsung Galaxy Duos, I permanently hit the neighbour keys. Is it like it commonly is or is it me, who just is unable to do it?
Yes, Duos is right. And yes, I am using qwertz (z instead of y). OK, very small keys, so I hope it is the keyboard.
try using a stylus with the phone. I love using one with mine.
I had bought one, not really tried out until now, good idea. To get contact / a reaction seems to be a bit diffuculty when touching the display (but using the fingers it sometimes is very difficulty to cause a reaction either).
Do you have large fingers? Try a keyboard which uses swiping rather than poking, something like Swype.
Yes, fingers are larger than normal. Yes, I had tried out Swype, it is installed on my phone, but as I touch the neighbour keys at the first touch and when swiping and at the end character, I am not able to hit the right characters like it seems.
You could use an alphanumeric style keypad. Select the Samsung keypad, then go into its settings and choose 3x4 layout.
