Root Difficulty rooting my Samsung Moment
jax4pres
I still have a Samsung Moment, and tried to root it today to 2.2.2 using advice from 2 sites, but neither worked:
How to Root the Samsung Moment – Volume 3 | Market 4 Android
How To Root Your Samsung Moment (2.2.2 Froyo) - SDX-Developers Forum
Here's the issue:
After carefully following the steps on each of the pages above, I run the updater to install: recovery3_1_1.tar which install just fine. After that step, I hit volume down, talk & end call buttons simultaneously. However, when it comes to apply to SD card (selecting M900-EB28-v1.1.zip), it applies it and then says error updating, saying (bad). Is M900-EB28-v1.1.zip "bad" or corrupt? Should I be installing a different rom instead? I can't get past this.
If anyone can help, it'd be much appreciated...
Jax
You may have a corrupt download or transfer. Often when the file doesn't copy to the sd card successfully it will show as 0bytes in size. Try copying to your sd card again, or downloading EB28 again, maybe with a different browser.
EB28 is a good starting point. To save a step, you could download BasicEB28, also found at sdx. It is basically the same as the zip you've downloaded but already includes a kernal. I'd then suggest applying a theme that disables Carrier IQ. Many of the EB28 themes at sdx do that. My favorite theme is Agat's Minimalist.
If you do want to stick with M900-EB28 and CrapKernal, don't follow the Market 4 Android instruction where it tells you to fully boot the phone after installing EB28. You will boot loop! Reboot to Recovery and install CrapKernal, then boot to system.
