I don't remember all the details, but there were many comments that this RUU may cause you to NOT be able to root, or change ROMS. There may be some help if you post in the Leak Pre 2.1 thread:hi guy's a different rom i have on there now RUU 2.1 and i cant get it off or update it to a different rom. can any one help with this. when i try to load a rom i get error cant open any sd recovery
thanks
i had everything else go as it was laid out. which said i was rooted dumb is it safe to say i don't need a recovery since i just wanted to try a different ROM anyway. or am i still in the same water or trouble. you can't see it what it says is. this is not found not i just did this from the puter. and didn't put anything on the card?
