I can tell you first hand its not as easy as the video makes out. I recently repaired my DHD after I broke the front glass!! Getting the front glass/digitizer off is fairly simple with a guitar pick and a hair drier. Only problem being is the ribbon that connects it to the LCD. Its easy to see where its connected once your DHD LCD chassis is removed from the motherboard etc but getting it out is another thing. You can't see it but its stuck to the chassis with some pretty sticky glue. If you just yank it out the ribbon will break and that's not the way to go about it. They say in the videos that you can just lever up the corner of the LCD screen to attach the new ribbon to the LCD connector.....again not easy. The LCD screen is really stuck into the chassis. You can get the complete chassis with new LCD and digitizer from eBay. Genuine ones cost
