Help dimensions for the battery?
akikhia
Android Expert
can u guys please give me the dimensions for the note's battery. depth width and height.
the stated voltage and actual max and min voltage would also be great
It would b greatly appreciated im trying to build my own extended battery that would make use of the extra space under the extended battery cover of the lg connect.
ive done all the research on parallel connecting lithium ion cells now i just need the right battery
any help is appreciated thanks a bunch
I don't have access to that type of information at hand, but have you tried googling it yet. Sometimes it is amazing what you can learn from a good google.:)
ok can someone take a picture of note's battery vs s2 battery? i want to compare width length and thickness please thanks.
Sent from my Transformer Prime TF201 using Tapatalk 2
you know, i was going to go out of my way and actually measure the note battery for you, but the complete impatience and lack of understanding that people around here have other things to do than anwser your post within minutes makes me change my mind.
there is a great bunch of really helpfull folks out here on this forum, don't make them your enemy
good luck
im not making enemies and i was a bit excited with the whole thing after trying the s2 battery and i saw how many views there were and i didnt want the thread to be burried in the back somewhere
i dont see how what i did is going to make enemies but thanks anyway
