Root Dinc2 sim card in Nexus 7? VZW
In a word,no. Your inc 2 is using 3g cdma frequencies,and therefore not even using the sim card that's in it.
Even if you had a vzw device using an LTE sim,the nexus 7 wuld have to be vzw lte capable. And even then,it prolly would not work,as vzw is stingy about using other carriers devices on their network ;)
you're prolly better off trying to use the nexus on a gsm network(t mobile or straight talk if you want prepay)
I've read and heard that the SIM card of any LTE device that Verizon certifies will work on the Nexus 7.
Yes and no. Any vzw lte SIM will provide the info that the lte nexus 7 needs to work.
However,not all SIMs are the same size,so an adapter may be needed,or the SIM cut down.
The other prollem is that,as stated above,the Inc 2 is not an lte device. ;)
