DARKTWOLF380
Currently the only problems I have are with the cpu settings, the temp, wifi, airplane mode, and forceclosings. I live where there is little to no signal from any cellphone company so i leave my phone on airplane mode and use wifi. sometimes when i have wifi turned off and go to turn it on, it says turning on but just sits there saying that until i do a reboot. the second of the problems is with service. I am able to use my service but i usually have to toggle airplane mode on and off repeatedly until it works and, once i finally get the service to work, my phone's temperature goes up to about 106-110 degrees F even though i have it underclocked to 1026MHz. next is that on occasion, the cpu will change back to 1504MHz without me setting it. The last of my problems is random apps such as facebook, email, and a few others randomly force closing all of the time.
If any one has any ideas on how to fix these problems, it would be very much appreciated.
*some side notes- I use performance control to change the cpu settings and i have acid sound mod v14 for the evo 3d installed and i am currently on DU2.0 and have had this problem since the first version i've used which was 1.8*
