Disable fallback to 1x...
Ice Nine
Does anyone know if there's a way to disable fallback to 1x/1xRTT from 3G? I basically want 3G or nothing.
Thanks in advance if anyone knows the answer to this :)
-k
Strange request, but I imagine if this is even possible you would have to find it in the programming menus.
I took a look in the service menu while I was in there changing the vocoder and didn't see anything (obvious) that would let me disable 1X.
The reason I want to do it is simple - I stream a lot of internet radio and when it drops down to 1X I get lots of stuttering as you would expect. I know that there's enough 3G signal end-to-end on my commute to stream without interruption. My Aircard had the same fallback problem, but in its menus it allowed me to disable fallback.
I'm hoping there's a way to do this in the Droid... I know it's doable on the 3GS via jailbreaking with sbsettings.
Looks like it's possible!
On the keypad, type: *#*#4636#*#*
Then go into Phone Info (topmost option) and select "EVDO only".
I'll see how that works :)
Update: Sure enough, that did the trick. Absolutely no fallbacks or stutters/gaps on my commute home!
-k
-k
You do know since you did this you wont be able to make/receive calls right just pointing that out
sorry to bump this, but im also curious on this, because i want 3g or nothing but would like to still make calls any one else know??
