Help Disable locking during calls ?
JoJoZ
I just got my Vibrant yesterday & I mainly love it !
The one thing I DON'T love is that about 1 second after a phone call starts, it goes into power save/lock mode/black screen, and I have to press the power button to get the screen back. This is during a call. Yes, I have set the regular power save options to stay on longer (2 minutes) but this does not affect it DURING a phone call. The saleslady told me it's a "feature" to keep your face from accidentally touching the touchscreen and unintentionally ending a call.
I really wish I could have the darned screen STAY ON during phone calls. It's such a pain to be dealing with some voicemail system & having to "press 1 for this, press 2 for that", but the thing keeps turning off IMMEDIATELY & I have to keep pressing the power button.
Isn't there a way to change this setting ?
Thanks.
You are aware that the phone locks because of the Proximity Sensor? It should also unlock automatically when you take the phone away from your face.
I've never had to hit the power button to bring the screen back up; in fact I've never heard of that.
No problem here...the screen comes back on in pretty much the blink of an eye once I take it away from my face.
I don't know if there's any way to disable the sensor, but I came across this on xda, posted by antjomn:
"Not sure if it its rom specific but when I installed upsounddown in the market it disabled the proximity sensor. (flip speakerphone did as well). Give that a try."
UpSoundDown - Android app on AppBrain
Flip - Speakerphone - Android app on AppBrain
Well, it's not because of the proximity sensor, because I'm using a headset. So the phone is not up to my face.
That is what I call "pertinent information." You may want to consider posting pertinent info in future posts requesting help. You may want to try Flip or UpSoundDown then.
Well, you know, I JUST got the phone. At the time I posted the question, I'd never even heard of a proximity sensor. I learned about it afterwards while attempting to solve the issue. I've been trying to learn more about the phone as much has I can -- 5 minutes here, 10 minutes there, in between working. A little hard to tell what's "pertinent information" before one knows anything at all about the product. :P
Thank you for the links. I'll check them out.
LOL, okay, point taken. Good luck! :cool:
MY GOD thank you. I was like why the hay is my phone locking during calls? I realized it was because I put a sticker over the sensor. I'm an idiot. LOL
