Disable Original Screen Lock on ZTE Warp
Marknderm
Does Anyone know how to disable the original screen lock on the ZTE Warp?
Preferably Without the extended use of a app. I would like to be able to disable it in some setting somewhere. If this is possible.
Update, I have found an app that does what I want, But it is an app not a way to get it into the settings, anyways I just thought that if anyone was coming to this post to try and find an app to do this ,,,Well here is on and I also found this other one that I did not get a chance to look at yet, but it may be worth it as well to check out. Let me know what you think if you use them, OK. Just in-case anyone else would like to know what you think as well if you use them too.
NO LOCK- https://market.android.com/details?id=org.jraf.android.nolock&feature=order_history or
https://lh3.ggpht.com/7kjyB9ExyjVIpIcAVXY1gYPaCXyv7xCp1CJPPNa0xIPdYAhJk7xt4FeYLYZy2zYbIQ=w78-h78
NO LOCK SCREEN- https://market.android.com/details?id=com.futonredemption.nokeyguard&feature=order_history or
https://market.android.com/search?q=no+screen+lock
Please let me know if the links do not work, I am still trying to figure out how to put this kind of info up on here. So your feedback to me,,, would be very useful to me,
I hope this will Help someone...
