Help Disable Pattern lock on I5700
lomlom
Hi, I just got my new samsung galaxy I5700 a few weeks ago. And Of course I manage to forget the pattern lock. do anyone know how to reset the pattern lock?
I know it's a similar post, but none of the answer there helped, so I really hope someone may be able to help. :)
If you try to do the pattern and get it wrong a bunch of times and it will ask you for your gmail password. Put it in (unless you forgot that) and it will unlock. Then it will ask you to put a new pattern.
