Apps Disable the "Settings" key of softkeyboard
I am an android developer . In my application , I am trying to disable the "Settings" key of android soft keyboard . I tried a lot but I didn't get a proper solution .
Even I tried with KeyEvents. It gives only the event of "Enter" key.
Please suggest with a proper solution which should handle/disable the "Settings" key.
Thanks in advance
