Help Disable usb insert notification sound
rdefino
Where in the world do I find the setting to tun on the sound notification when inserting the usb cable. I checked under sounds and it's not there.
thanks
It is under Settings > Sound > scroll down in the Feedback section and it is there, SD card notifications.
That is already disabled, and every time I plug the cable in it plays some radios station playback.
I did install zedge, but never picked something like this for the /usb/sd notification.
I uninstalled zedge, but it still plays.
I have the same problem. When I plug usb in, get an alert from any game such as scrabble or words with friends. It plays a song out of my library. It is extremely annoying and haven't found anyway to disable it. I even deleted the song that it would play, that did nothing except change the notification sound to default.
