Help Disable volume button sound?
its a TW based rom so should be. Il try it when i have a pen to write it down lol. Nice one mate thanks. I actualy meant to post this in gt-i9300 forum but i guess its just as relevant across the devices :)
Worked a treat :)
Can i add that you have to reboot after renaming.
Cheers Mike thats been annoyin me forever and i didnt think to just find out how to fix it lol. I love android :)
Age old topic, but still relevant as not many people seem to be searching for this...
I'm on LG G2. I am rooted, and found the folder as described. However, there is not TW_Volume_control.ogg or anything with "volume" in it...
The TW part is likely TouchWiz (this was a Samsung thread) and probably the rest of the names change.
Here's the same area on my HTC for example -
My point isn't neener neener neener, I have volume files - just that that can vary a lot by brand.
If you use a good file browser (I use X-plore File Manager) you can go there, tap each file you find, play, and get to what you want by process of elimination.
Let me know how it goes. :)
Thanks EarlyMon!
I had the exact same folder, and played through the sounds. None of them are the annyoing Android volume up/down sound :(
Will look further though!
