Help Disabled BlurHome.apk - Help!
Alright, so maybe I'm panicking, but I need some help. I was disabling/freezing some apps. Following a "safe to remove" list, and it mentioned BlurHome.apk. So I backed it up, and then disabled it. I then lost all ability to go Home, or to the applist. I restarted and got stuck on the Droid red eye spinning thing. I pulled the battery, powered up, and again, stuck on the Droid eye. How can I get back to Enable that app again, which is clearly not as Safe to remove as mentioned on the list. Thanks in advanced
Well I just did a system restore, and it's now up and running. Thanks
make sure you inform the thread starter that his list is actually inaccurate.
