I'm in Japan with my Nokia 6.1, running Android 10. My service provider is o2 (in the UK).  I am using a pocket wi-fi to connect my phone to data services.
I've done everything I can find to disable network data:
Nevertheless, when my wi-fi fails, my phone has switched to data over 4G, incurring hundreds of pounds of charges. (This may be using the VoLTE protocol?) I have therefore selected "2G" for "Preferred network type", disabling my phone's network connectivity (as Japan has retired 2G). o2 has not been helpful.
Are there steps I can take on my phone to disable data without the 2G overkill?
- Settings / Network & Internet / Mobile network / Mobile data: OFF
- Settings / Network & Internet / Mobile network / Roaming: OFF
- sent o2 a "NOTRAVEL" SMS on their 23336 number
- does Android One (v.10) still have a "Data roaming" option? If so, where should it be?
- can I disable VoLTE on my phone?
- if I disable "Data roaming" and VoLTE, will I be able to avoid data charges if I use a 3G network?
