Help Disabling Pattern keyguard @Home [Note3]
AngelicCore
Hi,
Searched around and found out that note 3 + tasker + secure settings, 'Delayed Lock' as well as 'Unlock with wifi' don't work for pattern keyguard
Was anyone able to do that?
Just to make sure, you mean on the note 3 right?
As far as I am aware (and I would LOVE to be proved wrong on this as I want this too) I think it's across ALL devices, Note 3 included. I did some research a month or two back and I discovered that there are loads of apps that allow you to bypass a passcode lock but none that will work with the pattern lock unless you are rooted.
I use this Bluetooth and Wifi Unlocker - Play Store for bypassing my passcode lock and it hasn't missed a beat yet.
You can do it with Tasker and Secure Settings if you are rooted. I did it with my last phone.
I thought someone posted an app in a similar thread that did this without root but it was a paid app, and not a cheap on, like $4.99 if I remember correctly. I can't remember the name though.
Check that, it's an app called Unlock With Wifi but it doesn't work with pattern lock or face lock.
