Hi:
I am sure this has been beaten to death already but I am not having much luck.
How do I disable the pop up blocker?
It would be nice to be able to check my payroll statement...
T I A,
Kevin
My iphone was much easier.
I am using the internet shortcut from the phone and can't find the menu on the browser?
I seriously feel like a moron...
You may need to draw me a picture
well apart from the fact that I feel like an idiot, my pop up blocker is now disabled.
thank you for helping the Android challenged!
Kevin
I went into the browser menu like you suggested and found the settings option. The pop up blocker was enabled so I clicked it to disable it. I can now use the site I was trying to access.
Previously I was using the main menu but couldn't find it there.
Thanks again for the help.
Kevin
Kevin
