Disabling Toggle Widget in Drop-down?
FitchVA
Member
I just got my Verizon version last night. I was wondering if there is a way to disable the switch/toggle settings widget that's in the drop down menu? Or is there a way to add settings to the existing bar?
I want a hot-spot toggle and only know how to do this with a 3rd party toggle that can be put on the drop-down list. If I can't add a setting to the baked-in toggle, I'd like to remove it so I can use the one I used on my gnex.
Thanks!
